HULL PINHOLES
Oct 30, 2019
30
Ahoy again Mateys! I recently inspected the hull of a 1977 Albin 27
that I am interested in purchasing. It had a significant number of
pinholes in the gel coat below the waterline. No signs of delamination
or serious structural issues. Can I assume that a good application of
two-part epoxy barrier coat will rectify this problem? Or will it
simply show up again? Has anyone seen this and successfully corrected
it? Thanks. Trev Leech.
Nov 8, 2001
1,818
Hi Trev
I had this on Southern Comofrt and just acleaned and applied four coats
of Gelshield Epoxy Treatment six years ago and all has been well since.
Cheers
Steve Birch (Technical)
Oct 30, 2019
23
I have had the same problem 2 years ago with my 1974 Vega. About 80 pinholes below the water line, a lot of them also in the keel, diameter of these holes approx. 0.5 - 1 mm. I filled them with epoxy filler and haven't applied a barrier coat afterwards, but no problems since. No new pinholes have showed up yet.
Best, Lucas
V2122
Nov 11, 2016
96
Nimble Arctic Toronto
Thank you, Lucas and Steve, for your responses. I am going to take
the Albin for a test drive this weekend. If all goes well, I may
become a proud Albin owner (with lots of fixing up to do).
AlbinVega@yahoogroups.com, "Lucas de Boer" lucas.deboer@... wrote:
