W
Warren
I have a factory blue 89 Catalina 30 that is badly oxidized. I plan on Alwgriping next season if I am unable to get it looking good. I have used Island Girl on my last boat (white hull) with fairly good results, however this boat is in much worse shape. I purchased some PolyGlow, and it did not remove the oxidation as I had expected. I needed to reomove some painted on letters yesterday and did some wet sanding, much to my suprise the area that I sanded looked fairly good when I was done. I would rather not wet sand the entire boat. Does anyone have a good solution to my problem. The PolyGlow folks have a new product called T-L Sea, which is a white powder you apply with a wet abrasive pad. I was only able to do one small area, then the rain came in. First impression, not a lot better than their PolyPrep had done. Perhaps a second treatement might do better, however I am running out of time.
