John Mark Connolly
Well, took the 14.2 out in small craft advisory (winds 20-25, gusts higher) and before I was past the docks on White Rock Lake, my windward sidestay popped. I guess 15 years is all you get of those these days.When the stay popped, my mast, sails, etc. took a dive. Recovered everything fine, but now I've got a hole where the mast step used to be. My question is this: is the core of the 14.2 balsa? Can I simply cut out the damaged part (it's all behind the wave break), match a slightly larger piece of balsa to the original core, and re-set a new mast step? Or, is this beefier wood, and what does the group suggest replacing it with?Any help is appreciated. This happened last summer and I've really got the itch to get wet again...John Mark Connolly
