The vinyl hull liner on my 1997 36s7 is pulling away and sagging. I have tried taping it up, but the tape won't hold on the fiberglass. Anyone else had this problem? Any suggestions? And it is spreading.
I had the same problem with my First 285. Even good adhesive doesn't work. What seems to work is wood firring strips "glued" to fiberglass under headliner with 3M 5200. This is the same adhesive used to join decks and hulls together - so you should not be able to remove later. I then used s.s. grommets and screws into wood. It seems to hold. This only works on long areas. I will try velcro and adhesive in non "load-bearing" areas. You may choose to remove the foam backing - or not, but it will be necessary for small areas.The vinyl hull liner on my 1997 36s7 is pulling away and sagging. I have tried taping it up, but the tape won't hold on the fiberglass. Anyone else had this problem? Any suggestions? And it is spreading.
