Auto Headliner with foam backing great on '77/27
I recently purchased a 1977 Hunter 27. I pulled old hull liner and went to fabric/foam wholesaler in Houston and purchased auto headliner. It comes in a variety of colors and is fabric over foam about 1/8"+ thick. I used the contact cement they recommended. I took my measurements, cut oversized on dock, did a dry run fit, then started with top and edges and glued in place. I spot glued, full on top and edges, you will be able to see what works best for you. The foam backing has stopped hull condensation and looks great. A very simple and inexpensive way to renew interior. I paid $5/yard for 5 yards and $20 for glue. I bought a gallon of glue. Didn't use more than a pint.
