Pat H
Folks HELP - My two year old H-26 has developed a serious leak.Water came up one inch above the cabin sole in a two week period while docked. It is very salty so I do not think it is rain water. I checked the compession post seal and the knot meter through hull and they look ok. There are no other below water line through hulls. The water appears to come up around the access cover floor fitting from the bilge below. The vee berth floor and areas below the cabin seats are dry. The water seems to be leaking into the bilge from either the hull or water ballast tank.I have not determined which.The rear bilge pump is below the center bilge water level but there is a 3 by 4 inch fiber glass hump across the bilge just behind the access cover. This hump prevents the center bilge under the cabin sole from draining into the stern bilge until the water level is above the galley floor level. If the boat is heeled the water can drain to the rear around the hump but if the boat is docked it cannot and as the bilge fills it seeps up around the access cover.Anyone have any advice on-1) How to find and fix the leak.2) How to drain the bilge under the cabin sole before it floods the floor. 3) Should the access cover be water tight? It was installed without caulk or o-rings and is not water tight. 4) Similar experiences?ThanksPat H
