A problem
I had a V222 and had the same problem. The early production years were before HID #'s were required, so they didn't have any. The only way to identify these boats is by the production number. It can be found on the starboard stringer up under the seats. For a better discription, go down the stairs past the winch handle, turn right twice and crawl in the long compartment going aft. It should be on your right. The problem is licensing these boats. You have to convince your State that this is the same as a HID #. Not always easy. Good luck and enjoy the singing keel!
