C
chamac
Hi AllI recently took my Oceanis 400 out of the water and have it on a trailer. It is sitting on the keel and is supported outside by pads at the saloon bulkhead and the rear bulkhead at the engine. I noticed the interior floorboards behind the keel are flexed slightly upward. Outside there is a slight "hollow" (for want of a better word) behind the keel. Obviously the weight of the hull and engine is causing the hull to sag slightly behind the keel. If the boat was dried out against a wall on its keel there would not be any support under the keel. Is this slight flexing normal or should the hull be completely rigid here? Is it safe to dry out this model against a wall say for cleaning?Any Ideas would be welcomeRegardsChamac
