Hull flex on a Venture 22
2
2 Venture Daytona Beach
Hey I have a 1976 Venture 22 and I have it on a roller trailer and the hull is flexing in about a quarter inch over a square foot area where the mid rollers sit. If you drew a line down from the rear of the windows down that is where the rollers are. Does anyone know how thick the hull is? If this is excessive or is the hull made to be flexible like this? The gel coat shows no signs of cracking, the screw driver test is good, and from the inside the resin and the glass look fine. I don't know anything about fiber glass and am not sure if it could be doing damage I cant see. Thanks !
Macgregor 22 Marina Del Rey, CA CA
I have a 22', 1971 Venture on a trailer with bunks. There is no apparent flexing of the boat hull. I crank down the heavy keel when the boat rests on the trailer to relieve the pressure on the hull. Perhaps you should replace the rollers with bunks.
Duane "novelman"
Jun 3, 2004
309
Prindle 18, beach catamaran Chicago (North Edgebrook), IL
I am with N-man, I think the rollers are the problem, as they don't provide the surface area of the bunks.
Feb 17, 2009
2
Yeah I actually am just going to put it in the water in a week. I found a nice place to anchor close to my house (intercoastal waterway). Any idea of hull thickness though?
Oct 23, 2008
138
Macgregor v22 Tacoma
The hull is really pretty thin maybe 1/4" if that. Go with the bunks and make sure the keel is lowered onto the trailer as was said already. If you can adjust the roller locations try to get them to set where the hull stringers are that should help. The keel box also has a pretty stout layup around it.
