hull fittings or openings
1
hunter 30 elephant butte
hello. can anyone help me with this. before i put my boat in the water. i would like to know what each of the hull openings are. i dont want anysurprises when i launch it and would like to check each system out, specially the raw water inlet and outlet. you can e mail me at junglecatjunction@yahoo.com if you have any diagrams. thanks.:doh:
There may be a Hunter 30 manual somewhere on this website. Have you tried Google?
Otherwise, it would be wise for YOU to track down each and every hose and for YOU to figure out where they are and what they do.
I had a manual for my boat, but I tracked each one down the minute I bought the boat, in fact I did it during the survey before purchase. Woops, even earlier than that: the day I first saw the boat and talked with the eventually previous owner, I tried each and every thru hull valve.
Apr 16, 2010
79
88 Hunter 30 Solomons, MD
Like Stu said, you need to track them down. The previous owner may have made some modifications.
What year is your 30? I'm sure my 30 will have different thru hulls than one made 10 years before or after.
