Hull Color Question
218
Catalina 30 Mark I Stockton, Mo
Hello All:
I recently purchased a Catalina 30, and I am trying to decide what to do about the hull. The PO had a vinyl graphic with the name of the boat on it. When I peeled it off I noted the color is different than the rest of the hull. The newly uncovered color is an off white, a yellowish-beige sort of color, while the rest of the hull is white. The Gel Coat on the rest of the boat is VERY chalky, and I wonder if the white looks white because it is so dead, and that if I sand down a ways the off-white color will come back.
My question is this: In 1976, did Catalina put out a color like I described? Or is it possible that the color under the sticker "morphed" into this off-white color due to different heat and/or sun absorption through the vinyl material? I tried to wet sand and polish a couple of areas of the chalky white part, and it sort of shines, but just a little polish on the off-white color really looks good! I'm thinking that the off-white is right, but I think that in order to get to it, I will have to sand the entire boat. Does this sound right?
Any help is greatly appreciated,
Mike Jewell
Foolproof #153
May 23, 2004
3,319
Mainsail has a process for restoring gel coat. You may want to get up with him on the main board and try doing that.
Bob M.
Dec 29, 2007
34
Catalina 30 TRBS Chicago
Yes, there is an off-white color
I have seen a few off-white Catalina 30's, and I'm pretty sure it was an available color at one time.
