Hull canned inward
Aug 12, 2014
33
Hunter 33.5 Sackets Harbor
Upon pulling my boat at the end of the season, we noticed about a 4 foot area underneath the galley where the hull was canned inward! Upon further examination, about 20 minutes later, it popped back out. Has anyone else seen such a thing?
Sep 4, 2007
776
Hunter 33.5 Elbow, Saskatchwen, Can.
Was it near the area the strap was sitting from the lift? If the strap isn't in the right place when you haul it can collapse the hull. I noticed this is your first post so have you had the boat long? Did the marina operate the lift or are you on a yard trailer?
Dec 15, 2009
25
Hunter 30 USA
I have seen that on other boats. Assuming it wasn't caused by the cradle or jack stands, either the lifting strap was in the wrong spot, the strap was not wide enough to distribute the weight (unlikely), or you have a weak spot in the hull. If it pops out and there aren't any cracks in the gel coat, I don't know that I would do anything about it except try to lift from a different spot from now on.
Aug 12, 2014
33
it turns out my cradle had some rotten wood in the stern support. My previous yard kept using it and i believe it stressed the hull. My plan now it to install an access port cover in the galley floor and have a look-see. Any thoughts?
Feb 20, 2011
8,062
Seeing as how it popped back out on its own, this doesn't seem necessary, but if it'll set your mind at ease, go for it.
How's that for ambiguity? ;)
Aug 12, 2014
33
My fear is that the water pressure, when she is floating again will can it inward.
Feb 20, 2011
8,062
I think the water pressure is much more dispersed over the hull than your cradle is/was.
Aug 12, 2014
33
Yes but, when it was pulled out of the water it was canned in and when out of the water it popped back out. Or the stress of being hulled "properly" caused it to pop in. I am perplexed!
Feb 20, 2011
8,062
Inspection port installation then, as you posted. How long have you owned her?
Aug 12, 2014
33
Ok drilled a 4inch inspection port in the galley floor. I reach down and i could flex the hull with one finger pressure. Its time to reinforce, lots of options, any thoughts from anyone that has done this.
RichH
Feb 14, 2005
4,773
Check for hull lay-up delamination in this area. If delaminated, then a proper structural FRG repair is indicated.
Use a plastic/phenolic hammer using constant force and speed to do the 'tapping' ... and 'tap-sound' the hull in this area -- from the outside.
Repetitively 'tap' the hull from areas that you know are not involved.
Keep tapping as you listen for the constant 'note' that the hammer produces as you move into the suspected area. If the (musical) note produced by tapping with the hammer becomes 'dull' or the 'note' lowers in pitch in the suspected area .... hire a surveyor to validate your findings.
Tapping across internal bulkheads, stringers or other 'structure' will produce a 'sharper' or 'higher' note ... and usually can be ignored.
Its the 'change' to LOW/dull notes when hammer-tapping that increases the index of suspicion for structure delamination in FRG composite structure.
Aug 12, 2014
33
I will start tapping however, with that amount of flex i think I will be reinforcing that area this spring. There are many schools of thought regarding reinforcing as well. I think West System will once again be my friend.
