Hull Blisters
Jeff Bacon
Hi All: Somewhere, recently, I read an article on the step by step repair of hull blisters. It could have been somewhere on this site, but, I must be having a senior moment and cannot recall where I saw it. Does anyone know of text or information that outlines step by step instructions for do it yourself blister repair ? Thanks..... Jeff
Dec 2, 1999
15,184
Not a senior moment, just TMI.
Jeff: You are not having a senior moment, it is just Too Much Information. There was an article by Pascoe he claims to know how to fix this. I really do not care for some of his opinions but it is a place for you to start. http://www.yachtsurvey.com/BlisterFail2.htm I would also search on "blister repair" on Google and see what else you find. There are as many opinions as ther are ways to fix the problem. I would find one that you find satisfactory. The one thing that is pretty much universal is that you need to open up the blisters and let them drain. You also need to flush them out so they are no longer acidic. If you are putting your boat on the hard, it is a good time to open them up and let them drain. You can start your repairs in the spring.
Doug T.
Blister repair
There are entire books on this subject. The common threads are: - Open the blisters
E
Ed Schenck
My library.
The West System people put out a separate booklet on the subject. If I remember I'll throw it in the car. Think WM or BoatUS may have it, about $4. But NOT on the H376!?
Bob Howie
Blisters
Well, as usual, Don pretty much has hit it on the head when it comes to the process, but there's a practical side to the issue of blister repair. Some of Don's methodology, although exactly accurate, might pose a problem from the standpoint of time, yard cost -- given whether you can set you boat on the hard someplace that doesn't charge you -- and how long you want to be landlocked. Yards here in Texas charge about $6,000 to $7,000 to totally strip the old gelcoat off the bottom, repair the major blisters, let the boat sit for awhile to maybe dry out as much as it can and then work their way back up to the point where they can put on the bottom paint. It could cost more or less depending on the problem. I've got a 23-year-old boat and I've got blisters and below-the-waterline gel coat problems that I just manage. I don't have any "sucking chest wound" type blisters, but it just becomes part of your annual costs and something you want to watch. If you are having these kinds of problems, you might want to haul your boat, clean off the bottom and then kinda map out and prioritize the worst problems in order to keep an eye on them and then work on them when you can. Good luck.
