Hull and Deck construction
Aug 17, 2022
3
oday oday 27 lake michigan
I'm looking at purchasing a 77 oday 27. I would be interested in knowing construction details. What the hull solid fiberglass, and was it cored above the waterline. I'm assuming the deck is cored. Does anyone have compression post issues?
And lastly I'd be interested in opinions and issues with the 27
thank you
Aug 17, 2022
3
Thank you for the links. Very helpful. I'm not finding much on the oday 27 so I need to just question in the forums.
Beyond that. The vessel I'm looking at needs some core replaced around the chain plates as well as the front hatch.
Lastly I need to replace the bulkhead (not afraid of that job). I guess my next question would be if it is worth all the work if I plan to upgrade in a few years. (Also has a good diesel in it.)
The rest of the boat looks really good.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Get an estimate for these structural repairs and request a repair allowance from seller. Even if the seller does not accept that make an informed decision on whether the boat is worth buying factoring in this cost.
dmax
Jul 29, 2018
1,268
Telstar 28 Buzzards Bay
It really depends on the extent of the rot/moisture - I had some around my chainplates and deck fills but was able to scrape it out with various tools from the openings (worst case was about 4" from the opening). I also applied a vacuum for a while to reduce the moisture content. Fill with thickened epoxy and re-drill the holes. Not a bad job, does take some time and you need decent weather. This can become a much bigger job if the rot is extensive however (many threads on how to do major deck repairs on this forum). If you haven't already, get/borrow a moisture meter and determine the extent of the moisture - if you have to cut the deck to access (from above or below), it's a bit more involved obviously. Also you want to determine if the deck still feels solid in the high moisture areas (use a brass/plastic hammer). It will be hard to find a boat that age, especially an O'Day that doesn't have some deck rot - owners need to keep on top of bedding deck hardware. The good news is that O'Day decks are cored with end-grain balsa so the moisture travels slowly. If the deck feels and sounds solid you don't have to fix it right away.
