I'm still struggling with the engine and just don't know where to look for problems.
Previous problem with electrical pump was solved and running now.
Now my suspicion is HP fuel pump and need some opinion from members/owners.
Running fuel pump is attached in a small video.
Right now engine starts really hard and puffs quite a bit of white/dark mix of smoke for a minute until engine starts to warm up, after that there is no smoke. RPM is not steady as it goes up and down a bit. Engine runs to the point of reaching operating temperature and then slowly lowers RPM until it stops.
I need to mention that disassembling the engine for small rebuild noticed that water pump was seized to the point that the connecting notch on water pump was twisted. This Sherwood water pump is run by the cam shaft driving HP fuel pump. Just wondering if that might do something to fuel pump as for me it doesn't push enough fuel.
Any observations and pointers are greatly appreciated.
