The traveler at the stern is loose (the screws have loosened where the traveler is attached to the fiberglass). Any ideas to secure the traveler to keep it from moving back & forth??? Thanks, Cap'n Jones
You can remove the entire unit, put tape on the back side of each screw hole, mix up some epoxy with filler & fill each hole. After cured, drill appropriately sized hole & reinstall traveller.Or maybe you could just use bigger screws?LaDonna
