Raw Water Accumulation
Regarding the two prvious posts:1. Don't crank the engine for more than 15-20 seconds. If it doesn't start, FIND OUT WHY AND FIX THE PROBLEM! Drain the water lift muffler before trying again. Most likely problems: lack of fuel (clogged filters, air in fuel system, bad fuel pump, injector, etc.) or a bad glow plug (or its wiring).[Incidently, excessive cranking can really ruin the starter, too. It can overheat to the point of melting solder and wiring insulation.]2. A following sea shouldn't cause any water accumulation in the muffler if the boat is equipped with an anti-siphon loop in the exhaust.The water lift muffler is generally mounted below the engine, and the seawater/freshwater heat exchanger high on the engine for a good reason -- to keep seawater from backing into the engine (generally the oil sump).--Ron
