How to wire low oil pressure switch
MH
Mar 21, 2005
23
- - NC
My "new" Cat 30 had no low oil pressure signal when I bought it and now I know why. There is no alarm in the panel. I have one and know the oil pressure switch works because I wired it up in the cabin to check it. Now I need to install the alarm. There should be a lt blue wir going from the oil pressure switch to the negative terminal of the alarm. I found it leaving the engine but nowhere behind the panel. I will find it and connect it to the negative terminal. Now I need to connect the positive terminal to a switched positive connection. Where does it connect? I think it connects to one of the switch terminals? If so, which one? Thanks.
weinie
Sep 6, 2010
1,297
You would want to connect it to the terminal on the key switch that is off when the key is "off" and on when the key is "on".
