How to test a fuel tank sender
240
Hunter 41 Longport,NJ
No matter how many times I try re-wiring my fuel guage - it is either pegged on full or empty and never moves - wondering if there is something wrong with the sender - is there a simple way to test it ?
Jim
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
A simple ohm meter is all you need. The resistance in the output changes with the level of the float. It should have a steady change as the float sweeps through its travel. If it jumps around or doesn't move it's finished.
