I have a Hunter 28.5. I have installed a new strut and replaced the 1" shaft with a stainless steel one and am installing the PYI packless shaft seal (PSS). I have the shaft thru the strut and shaft tube and now have the PSS installed (not tightened) but the new split coupler now must be tapped on the engine side of the shaft but it has a very tight fit and will require a non-marring hammer to do it. The problem is that I have no room behind the transmission between the output flange and coupler to swing a tapping hammer with sufficient force to fit in the coupler to the proper location on the shaft so that I can complete the installation and align the Yanmar properly.
I read where someone had to remove the engine to insert the shaft from inside the boat after tapping in the coupler. I hope that is not what I will be facing. I see no way to do it inside the boat with the limited room. It will take forceful tapping to get the coupler on the shaft. Any suggestions out there will be greatly appreciated.
