COUPLE OF OPTIONS
Bob: The gasket on the ports becomes dried out and brittle over time. I had an '85 Hunter 31 and battled the same problem. One thing you can do is use a silicone grease on the gasket which will temporarily provide some moisture and allow a better seal. Worked for me. You can also get replacement gasket material from the manufacturer. Not sure who made your ports (probably Bowmar or Beckson/Grey) and both have gaskets for sale. For that matter, some West Marine stores stock the stuff. I suspect that you will be looking to replace the ports before too much longer, so you probably don't want to sink too much effort/time into a fix, but try the teflon/silicone grease trick first and see if that helps. Good luck!Tim LeightonS/V "MAGIC" (C-400)
