A
Andy
When the weather warms up I'll be putting in a VHF cable from the top of the mast of my Tanzer 26. It seems there are two ways to go: (1) down the mast, or (2) taped to the backstay. The only disadvantage that I can see to taping it to the backstay is that it would look lousy -- and maybe some windage. If I run down the backstay, I can go with a single length of 50' stock RG8-X complete with PL-259 connectors on each end -- right from the radio to the antenna. I'd drill a large enough hole in the top of the transom to get the connector through, and plug it with a slit rubber stopper with a hole drilled in the center. There would be no worry about water doing damage, because the top of the transom is not cored. This would be easy to remove and install each year. The cable could run straight or have gentle bends (desirable) right to the back of the VHF transceiver. If I come down the mast, I have to go through the cabin overhead (cored), and an easily removable slit plug wouldn't be sufficiently water tight. Therefore I'd need connectors to make a break as the cable went through the deck. I don't see anything specifically for this in catalogs. I'd have to get the cable inside the mast, prevent chafing at the entry holes, cut the cable to exact length down the mast, and so on. So going down the mast looks like a real project. Further, the extra connectors would mean some power loss, and an opportunity for corrosion. So coming down the backstay would be much easier, and better electronically -- but I don't know that I have ever seen it. Is that only because it looks lousy, and nobody builds boats that way?
