Main sheet rigging, still need vang rigging info
JackStill haven't figured out the vang rigging. I could just put a block & cleat at the base of the mast and forget about the line going through the cuddy cabin then along the port side of the center board.Main sheet is no problem. I have double pullies on both the boom and at rear of the center board housing with cleats on either side of the lower pully.Sheet attaches permanently to the lower pully, goes up to the larger of the two pullies on the boom, down to the larger lower pully, up to the smaller boom pully, back down to the smaller lower pully. After that it just cleats depending on the tack.If this doen't help let me know & I'll take a picture and send you.Can you give me any feed back on the vang?
