Throttle Cable Blues
Tom, I just replaced my cable last fall. My problem was the forward and reverse cable was bending before it was going into the cable sleeve. But your problem is very similar to mine, I replaced both cables. This was due partly to age and contamination inside the cable sleeve and not wanting to do it again any time soon. Check to see if the cable lever is moving without hitting anything, or maybe it is loose at the connection to the cable. The cable sleeve will have a yoke and a mounting bolt that holds it to the pedestal. This is down inside the pedestal, so be real careful not to drop anything down inside it and extra careful not to strip any bolt holes out. The other end attachs to the fuel lever on the fuel pump. It just unscrews there.Look at your cable, one end will fasten to the fuel pump, the other end will have the saddle and mounting piece to bolt it back to the pedestal. You will have to have access to the bottom of the pedestal so you can bring it down through the floor along with the other forward/reverse cable. At this point I don't know how your boat is configured, mine is a 1987 Hunter 31. But attach the new cable to the top of the old cable somehow, (I used good ole Duck Tape)and pour some liquid soap on the connection to make it slide around corners and go through holes easier and pull it from the top of the pedestal down through the bottom hole of the pedestal. This is where it gets very tight. Hunters Engineers didn't give you much room to do this. But once you get it down and through the hole, (this would be a good time to have a drink)you can push it through the other places where it goes back to the engine. Don't tighten up anything until you have one end in the engine room and the other end sticking out of the pedestal. Also, make real sure you get the right length cable. There will be a Part number on the old cable sleeve somewhere. I got my cable from West Marine. Just give them your old part number and the length and you should be home free. Just remember, keep cold beer on hand, and a good helper/goofer around, oh, and you may want to have a bottle of good Rum somewhere, it always helps. Let me know what happens or if I can help you anymore. Email me at: robt.syl@sbcglobal.netRobert and "As Time Goes By" from St. Louis, MO.
