New to me 2005 Capri 22 has a storm damaged motor mount. What is the best way to access the nuts holding it on? It's frame is bent and the handle/stop piece is missing.
An access port? Would one in the fuel locker give access or is there another layer? The top rudder gudgeon is loose, so an access port is needed there in the middle anyway. Do I need the large on Catalina Direct sells for this?
Should I crawl into the quarter berth and hope to not get stuck? Anyone have pictures or drawing of what is back there? How did the factory install the mount? A threaded backing plate would be nice, is there one on a 2005 model 2? Then I wouldn't need access to the back, just make sure the plate doesn't fall.
I'm a new owner for the boat and it needs some work. It will be in Daytona Beach, and I'm hoping the wing keel will be nice for the shallow water we have here.
charles
charles
