When your skylight leaks, panic ensues. How to fix it?
Under no conditions should you slap on some silicone & hope that holds. It will not stop a leak, and will make it very difficult to adhere anything to the surface afterwards.
You must remove the wiindshield / skylight, and re-seal the whole thing properly. Here is an easy way to do that.
