How to remove cotter pins
Sep 20, 2006
367
Oday 20 Seneca Lake
I am replacing the back stay and can not get a grip on the small masthead cotter pin in order to bend them straight for removal. Anyone have any tips on how to remove the pins?
Likes: All U Get
SFS
Aug 18, 2015
2,083
Currently Boatless Okinawa
They make a pair of pliers that has a small protrusion between the jaws. That protrusion goes into the "head" of the cotter pin, then the jaws clamp shut. Then you just muscle the cotter pin out - the "legs" will straighten (sort of) on the way out. I don't know what they are called, I had a rigger give me a pair one day.
Edit: Just did a google search, and they make cotter pin removal tools, but none of them are the pliers I saw. Pictured were various tools that would use leverage because of their shape, rather than brute force needed with my pliers. Do a search, see what you come up with. If you own a sailboat, it is a tool worth having.
Sep 30, 2016
365
Island Packet IP 44 Ventura, CA
You can also try using a small 90 angled pic or hook. Common in tool sections. Hook onto the head loop and pull.
Sep 20, 2006
367
Oday 20 Seneca Lake
Was finally able to get a needle nose vise grip on the loop that held it from spinning so I could pry open the cotter pins. Unfortunately when I got the old back stay off and put it next to the new on the old one was a foot longer. May have to reuse old one for another season.
Joe
Jun 1, 2004
8,161
I have on of these, except it's from Home Depot... "Rigid"
