how to remove a fuel injector on a M25XP diesel ingine
6
Catalina 30 tall mast Bellingham
How do you remove fuel injectors on a Universal M25XP diesel engine?
If you could provide some information on how to do this it would be greatly appreciated.
I can't find any information in the manuals that I have looked at -- can you recommend a manual.
Does it take any special tools when removing or replacing the injectors and when you do replace them what do they need to be torqued at?
Thanks.
Jim
pk104
Jun 30, 2009
208
Catalina 310 Atwood Lake
Google Universal Service Manual 200554. I believe it disc ribs how to service them. Getting the engine hot will before you try to remove them will help and there are washers under them you don't want loose. Try to vacuum up the dirt around each one before and after removal so it doesn't get in the fuel system.
Are you sure they need to be removed?
Gary
May 20, 2013
6
Gary,
Thanks for your help.
As it turned out it was not the injector but an air leak coming from a fuel line at the injector pump.
Again thanks and happy sailing.
Jim
