Why not do it yourself?
Mike- How about finding a fixed buoy, placing a marker in your GPS, sailing upwind to a point where your Windex is pointing directly back at the buoy (ie, it is DDW)- and note the compass reading to the same. Then sail for max VMG to the buoy, according to GPS, noting the compass heading again. Calculate the difference. You should be able to find the optimum number of degrees to sail off DDW for that particular set of wind conditions. On most boats, polars change a LOT as wind strength is altered, so you may want to do this several times under various conditions. In general, better VMG is made heading up under light conditions. The harder the wind, the closer to hull speed you are anyways, so better sailing closer to DDW. Bruce
