Finally got my 1991 H23 in the water, for first time as its new owner.
Now comes the mast tuning. I have seen the various comments about using approx 2% rake, and another about 6 inches of prebend (at least for a 21).
I can see how to use the outer stays and the swept spreaders to control bend of the upper mast (more or less, at any rate), and have seen how to use the lowers (inner stays) to pull the center of the mast side to side to straighten it. When people say "X inches prebend" what does that mean? Is the 6 inches the measure from a straight line from masthead to mast base to the mast, at the longest distance from that imaginary line to the mast? Is it how far back the masthead is from vertical? How on earth do you measure it?
Visually, mine has a noticeable aftward bend from the spreaders on up - if I had to guess (well, I guess I do have to guess) the masthead is maybe 6 inches behind the totally straight-mast position.
Maybe it is easier just to sail it, and observe the sail shape and handling? That begs the question - what do you observe in the sail shape to tell you what to adjust for the bend?
