- Jul 21, 2013
- 333
I ask this question to the audience of this forum because the skills and knowledge I have observed is unsurpassed.
I had some repair done to one corner of a removable fuel tank cover which is also the floor of the cockpit.
After the repair, it does not want to fit flat. I have spent a few days grinding with a 4" grinder taking off the high spots, putting it back in to test the fit but there is still some adjustment needed.
I am using an inspection camera through the inspection port to see all around the edge using sunlight as my guide and mark the dark areas for grinding.
The technique I am using does not seem efficient. The cover weighs approximately 150lbs and it is not easy to take in and out of the boat.
What are the tricks, tips to have it sit flat? Am I missing some other trick to mate the two surfaces?
I also thought of some how making a mold of the 2" ledge where it sits. I thought of using pour foam to make a male plug and then glassing the 2" ledge to build the mold and use this mold over the cover to check for clearance and grind instead of picking up the whole cover back into the boat. The fiberglass shop I went to get the supplies for pour foam advised me on the difficulties of using foam as it wants to stick to everything and I should be careful on how I mask and prepare the surface.
- Deck upside down
- Foots I installed after the repair was done to have it sit on the ledge
- This is where it has to fit
