How to make a continuous furling line??
Stephen Baltes
My 2001 Hunter 320 came equipped with the in-mast furling main option, and the dealer installed a continuous line for the main furler. This is one of my favorite features on the boat, but after several years of use the splice is becoming weak so I need to have a plan for replacing the line in the near future. So my question is how to best make up this furler line? I'm sure splicing line is a skill I should probably learn, but are there easier alternatives? And does it even need to be a continuous line? Thanks for any suggestions . . .
Steve O.
splice
You can have a rigging shop make the splice if you can figure out how to install the line after its done. Or have a rigger come to the boat and make the splice, but that wouldn't be the cheapest way.
G
Greg
Not too hard
It's not too hard with the right tool. I found the concept of making this splice fascinating -- inserting double braided line inside of itself! Let me know if you decide to do it, and I will find the name of the tool I used. If it's for a roller furler, I can't imagine doing the splice off the boat.
Paul Aubrecht
This is what I did
I have a furling that required a continuous line.It broke while sailing.What I did was,take one end of the line,skin back the outside shield about 1 inch,then I took the other end and cut back the core the same.I then put the longer core end into the shorter core end and using a sail repair kit,sewed the Crap out of the junction.Then I taped the junction.Seems to work well so far.
L
Les Andersen
End to End Splice
Stephen, Directions for splice enclosed. Have fun. Les s/v Mutual Fun
G
Greg
Get a fid made by this guy
If you are going to do this splice yourself, get/borrow a good fid. It's a must. I used one from Brion Toss and it worked well. When you get to the website, look for a "splicing kit." I think West Marine may have them as well.
Steve B.
Thanks everyone!
Thanks ya'll! I'll be ordering a fid and some line to practice on here at home so I can redo the line on the boat this spring. I'm reviewing the New England Ropes site to see which type line loons the easiest, and I need to double check the size line recommended for the furler.
