My owner manuals indicate that simply lubricating the mechanism at the console and putting lube on the exposed cables at the engine end is sufficient.Is this really true? Is there a way to force a liquid lube inside of the cable casing to lubricate the entire cable? I used to lubricate the clutch cable on my motorcycle using a special clamp that had a rubber seal that was attached to the end of the cable. A liquid lube was then connected to the clamp with a plastic nozzle and the lube was forced in one end of the cable and out the other.Has anyone done anything like this?
