Batten Retention
Retaining your battens in their pocket may call for a little more effort. I repair a lot of sails and quite often install missing battens. I drill a hole or two in the batten end and I sew heavy thread through the hole and the sail. If you sew it right, you can even put a little tension on the batten.Do you know what batten poke is? Batten poke is an undesireable and relatively sharp deflection of your sail at the front of your batten pocket. Sometimes, batten poke can be reduced by using battens that are lighter or that are tapered to a thinner fore section. Another cause of poke is a batten that is too short for the pocket (and therefore untensionable).The concept of selecting the correct batten and batten tension is an art form. You must retain and tension your battens for best effect. The little tuck of material at the trailing edge of your batten is a great place to sew and anchor your battens, I would not trust that little flap alone. Small bungee chords, velcro flaps and lacing ends retain and tension battens.Do you need new battens? I can help
