How to Install Inverter on Beneteau 41
May 25, 2013
36
Beneteau Sense 50 Waterford Harbour
I would like to install a Mastervolt inverter on my 2012 Beneteau 41. With such a limited owners manual and electrical connectivity diagrams, does anyone have any good information how I can do this myself? I'm not looking for inverter sizing help per se but rather the tieing it in to the charging system. Or is it worth the extra $$ to have it installed for me? This seems straightforward....if I know how to identify the wiring feeds. Plus it would help increase my electrical system IQ...
Gunni
Mar 16, 2010
5,937
I have an OEM 3000 Watt Inverter which I am going to have removed. It ties into the house battery through a disconnect, then onto a standby/active switch, feeds AC back through my port side 120VAC outlets. I consider this kind of major system install to be a pro-install (ABYC-cert'ed).
Mar 5, 2008
58
Beneteau 43 Alameda
also installing an inverter
I'm in the process of doing the same thing. I've mounted the inverter adjacent to the house batteries to keep the battery cable run as short as possible. On my 43, Beneteau left a blanked off spot for a battery disconnect switch under the main battery disconnects. I bought the same style disconnect from them and tied the house batteries on a new fuse through that disconnect to the inverter. This gives me an easy way to just isolate all of it.
On the 115VAC side, I've got auto transfer switch, so when I disconnect from shore it will automatically transfer to Inverter. I'm picking up the 115 just past the 30amp breaker in the aft lazerette, running shore power down to the autoswitch and then back to the aft lazerette where I'm picking up the power that leads to the main panel and the two 15amp breakers. From there it's the same. Essentially I'm just inserting the inverter and transfer switch into the circuit between the two sets of breakers.
I've got a remote inverter panel located on the same door as the radio and stereo. That's a simple phone cord interconnect to the inverter. That's the easy part.
The only item I'm still considering is a three way power switch in the aft lazerette to allow me to bypass the inverter / transfer switch in the event if fails. I like options. Blue sea makes a nice three way rotary switch.
Just prepare to be contorted to make the wiring runs.
Fred
