How to get the same tune when takimg down the mast and re st
Aug 27, 2012
98
Hunter 1990 Hunter 35.5 Toronto
just bought a 1990 Hunter 35.5 and we are trucking to our lake. The mast is up and tuned. any suggestions of how to get the same tension I was thinking of measuring between the toggle bolts or taping them?
any issues with the furling. I have a pro furl which is above Deck
Thanks Floyd
May 16, 2007
1,509
Boatless ! 26 Ottawa, Ontario
I had my rigging tuned by Steve Pettengill formerly with Hunter Marine. He told me if I needed to take mast down just release the forestay, do not touch the stays. Then just reinstall the mast and re tighten the forestay.
I have not tried that but seems like a plan.
Bob
Nov 26, 2012
1,654
C&C 40-2 Berkeley
Keeping the tune
Just disconnecting the forestay works if you have a B&R rig. Also, it means you have to get the mast down and store it without disconnecting the rest of the stays. It can be done. I put tape on all of the turn buckles to mark the their locations. It all depends on how perfectly tuned you need it to be.
Dec 27, 2004
139
Hunter 340 Burlington, Ontario, Canada
We take ours down annually for winter haul-out. Just tape the threads on each turnbuckle....works fine. Also the rigging all disconnects easily from the mast (on our 340 at least) which might be good for shipping too. Label each segment tho to avoid a lot of head scratching when putting back on...with all the diagonals in can be a little confusing!
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
Re: How to get the same tune when takimg down the mast and r
the taping of the turnbuckle screws is a good way to get it back close but you might want to invest in a loos gauge and use it to fine tune them in order to get a balanced tension on the rigging weather you race or not it is best to have a balanced load on the rigging ei if you have 8% of breaking strength or tighter for racing ....just my personal preference to have a balanced load
Hunter Legend 40.5 Rock Creek
I have heard of using fingernail polish to mark the position on the threads of the turnbuckles. I've never tried it though.
That's a good idea, but could be considered to be too permanent. I use a yellow Crayola crayon.
