Angle of LOLL
Hello Robert,I agree with everything you have stated.My thoughts were that perhaps they have managed to raise the centre of gravity of the boat above the transverse metacentre. The G would certainly shift upwards from G with any additional weight suspended at the masthead. It looks like they are using two large water bags which could hold at a guess several tons of water.From Ladage's Stability and Trim."If the centre of gravity lies above the transverse metacentre (G above M), the vessel is in a state of unstable equilbirium, that is, she possesses a negative GM. There is no tendancy for the vessel to right herself at small angles of inclination. An upsetting moment is formed ant the vessel will incline from the erect position. A negative GM does not mean that the vessel will capsize. It merely means that the vessel does not have any initial stability , and that she will incline to an angle where B has moved far enough to the low side of the vessel to be once more in the same vertical line as G.Apparently, then, a vessel can acquire a list not only by having its center of gravity off the centerline but also by having its centre of gravity too high in the vessel"My description of metacentre in my original post was not very well done. I tried to keep it simple to prevent simialr responses e.g. from stillraining. I am not saying that this is what they have done. Without the stability curves for the boat and all of the information - It just a guess.I have commanded drillships in Brazil that had very small initial stability, i.e. small values of GM - it's not a comfortable position to be in. My response is probably way more technical than people are interested in. For this I apologize in advance.Regards
