How to fish wire thru the mast
Michael
I have been quoted a rather hefty price by my local boat yard to fish wire thru the mast (32' Oday). Is this something I can do? (I have a 100' fish tape)
G
Gord May
YES, you can
fish a wire through your mast, just as easily as can a "yard-monkey" (no disparagement implied - I've been one). Hope your mast is down, and you don't have to go aloft. Gord
Shane
I have heard but never tried
That if you attach a string to a steel bolt and drop it down the mast and use a strong magnet (on the outside) to keep the bolt at the side of the mast you can guide the string down the mast with out getting it tangled. Then you use the string to pull the wire through the mast. If you try this let me know how it works. Shane.
Rick D
Jun 14, 2008
7,206
Bike Chain
Someone in a publication suggested using a bike chain tied to a messenger line. Theory is the chain is a small cross-section and will snake around obstructions. RD
Jack Jackson
The string and magnet method works!
I used the string and magnet method to snake a wire up the mast of my ODay 25. The mast was on sawhorses at the time. I took the masthead casting off, then tied a nut to some nylon string. I fed the string from the top of the mast and used the magnet to pull it down to the bottom. It took two or three tries, but worked surprisingly well. I attached my wire to the string and pulled the whole thing back up. Total project time was about an hour. Jack Jackson
G
Gord May
Your Fish Tape
is probably the easiest way to fish the mast. These other (magnet & chain) ideas are more in the way of substitutes. Good luck. Gord
G
Gord May
Your Fish Tape
W
Warren
Measuring Tape
Depending on how long your mast is, a long "tape" may do the job.
Bill
More info
With mast down and mast head off, ran a stiff wire on my 24 ft. mast thru a small access hole near the base of the mast to the top of the mast. Then secured my VHF coax to the wire and pulled it back down through the mast and out the access hole through a rubber grommet. Seemed to work fine. Good luck.
