In the immortal words of Bart Simpson, "Doh!"Joe Ford made a suggestion that sparked an obvious change to the forums: there's no reason to require an authentication code for folks who are logged in.So, if you register (still not required to read or post), log in, and check the box so the server "remembers" you, you can post without that annoying four digit code that must be re-typed.You can still use the forum without registering, but you won't get an avatar, and you will get those annoying codes when posting both topics and replies.Thank Joe for saving you all those extra keystrokes.
