How to deal with tiller handle wear?. . .
Steven Gautney
Bolt holes in the metal tiller handle are enlarged due to wear(I assume from the motion of the waves when fixed at dock). This makes the tiller too loose. I have tightened bolts but this is short term. I'm interested to know how others have fixed the problem. Do I need to simply replace the handle? Has anyone replaced the metal handle with a wooden one?
Rick Webb
Mine Too
I took mine to a machine shop they welded in a bushing so that it is a solid peice of metal where the bolt hole is. After all of that I used a longer bolt so that the threads were not chewing up the tiller. Put a wing nut on the end of it so that I can move the tiller to the other side of the rail and get it out of the way when at anchor or messing around in the cockpit. I am still thinking of getting a wooden tiller as that pipe gets damn cold while we sail in that frigid part of the year when it gets down to about 50 or so.
L
Larry Mongeon
Old Is Good
When I bought my H25 the tiller was completly delaminated 6 strips apart and the bracket holes worn to point where there was all sorts of play as you described. A friend helped me to re glue using west system epoxy and he used the same west system to fill in all holes where bracket was mounted. I then simply redrilled holes, sanded and varnished with a good marine quality uv resistant varnish. The tiller looks and functions as new. I did make a tiller cover and will never leave tiller uncovered when on the hard.
