Man, that was funny!!!
Seriously LMAO!! The only problem that I can see is that the missles used are rather large and bulky to store. It seems that perhaps something smaller would be easier to work with and still have the required range and terminal effect. Also, radar guidance would probably be better than heat seeking, it'll be at least a couple of years until the PWC jockeys get wise and start installing chaff generators and electronic counter-measures, so we could have a real field day in a 'target rich environment.' What we need to do is get the sailboat builders to start including these systems as factory items. To help keep the element of surprise, I'm envisioning something along the lines of a second anchor locker at the bow with hydraulics to raise and lower a set of six smaller missiles that are linked to the boats radar system. With the proper software, you could have multiple targeting capability along with 'fire and forget' functions. A system like this could be quite effective in 'thinning the herd'!! *5 ;D
