How do you wash your rags/pads that you use for waxing/buffing your boat? What type of detergent do you use? Any products that work really well? I don't seem to be able to get the wax/polish off the rags. I also worry about it coating my washing machine and then having it get on my other clothes when I wash them.
Pads should be used only for compounding, polishing & glazing (creating the shine). Wax is applied by hand and removed by hand. Wax is a Protective layer only, it is never intended to "create shine" only to enhance and protect. Machine removal actually "re-melts" it and leaves you with less protection. Waxes, most all contain silicone, will RUIN good wool pads. Best to just not go there.
If you only use "body shop safe" polishes & waxes, such as those made by Presta, not the amateur level products sold at marine stores, you'll find they are water based and don't contain any of the "cheater oils" that also ruin pads.
Simply hand wash the pad in a 5 gal bucket then apply to the machine and spin in the bucket at high speed to dry it..
If you absolutely have to launder them, front loader, cold water, Dreft, Ivory Snow or Woolite only. DO NOT machine dry......
