I've got a 1991 P42 with the same problem. I've never been able to completely clear the tanks of the stuff, and it eventually clogs up my filters in my fresh water system. So I just keep cleaning out the filters. Not too big a deal.
BUT it sometimes clogs the lines where they connect to both the forward and the aft water tanks. After much pain and experimentation, I've developed a system that works reasonably well. I have a PVC "T" fitting right next to my water pump with a threaded cap on the end of it. I also have a 12" flexible hose with a threaded female end on it. When the line is clogged I unscrew the cap, screw on the hose, and blow in the end of the hose until it dislodges the crystals that are blocking the outflow from the tank. It's easy, takes only a minute, and solves the problem for quite some time.
If anybody can tell me how to totally dissolve all the remaining crystals, and the stuff adhering to the insides of the tanks that causes them, without destroying my 20-year-old tanks, I'll be your friend forever.
Cheers,
Paul.
