It depends...
As David mentioned, bareboat certification is not mandatory, especially if you charter outside the US. It's just an indication that you've met the MINIMUM requirements for managing a boat, and gives the charter company some idea of your sailing and boatkeeping ability.However, even if you are certified, the charter company will probably still ask you to take a check ride. They want to see your ability for themselves, because some people inflate their sailing resumes. The last thing a charter company wants to do is turn over a $100,000 boat to someone who's going to run it into a channel marker on the way out.Here are a few tidbits from past experience: The check ride may be up to four hours long and it IS considered part of your charter time. A seven day charter is usually not seven 24-hour days, it's actually seven days and six nights. Going over the systems, the chart briefing, the check ride and provisioning the boat will easily burn up the first day.Here's what I'd suggest. Sign up for the two-day ASA Basic Keelboat school at St Augustine Sailing (www.sta-sail.com). Don't let the word "basic" fool you. The instruction is thorough, they cover more than the B.K. course material, use 30-foot boats, go out into the Atlantic and the price is reasonable. Since you already have experience, you can concentrate on developing new skills while your less-experienced classmates are still trying to remember the names of all the parts of the boat.Added plus: The area around St Augustine Inlet is tricky. There are shifting shoals, strong reversing tidal currents, few aids to navigation and a seabreeze that builds a wicked chop when the tide is ebbing. If you're confident sailing there, you can sail just about anywhere.Finally, if you don't already have one, start keeping a log book. When it's time to charter, take your log with you and produce it at check-in. The mere fact that you keep a log speaks volumes to the charter company about your attitude towards sailing, with the added advantage that the proof of your ability will be right there for the reading. Good luck.PeterH23 "Raven"
