Isofurl by Isomat Spars
My O'Day 302 had a jib furling system made by Isomat, called an Isofurl. It uses a unique sail hoisting system, which is described in the attached web site:http://www.rigrite.com/furling/Isofurl/ISOFURL_Main.htmlWith this system, the sail has a special locking device attached to the head, and when the sail is fully hoisted it locks itself at the top of the sail foil. The halyard is not permanently attached to the hoist ... it is fastened with a hook that has a retrieval line, so you pull the halyard back down once the sail is locked in the hoisted position. Then you tighten the luff by tensioning the foot of the sail attached to the drum. The halyard is not used again until the next time you need to raise the sail. To Lower the jib, there is a wire "trip line" sewn into the luff of the sail. This trip line is attached to the release mechanism at the top of the sail (you need to be sure to attach this trip wire to the hoist before you raise the sail!). When the trip wire is pulled, it unlocks the hoist car at the top of the foil, and the sail just slides down the track. It sounds complicated, but it's really quite simple. Another feature of this system is that there is no forestay inside the sail foil ... the sail foil is the forestay! Again, read about the system at the url I provided at the beginning of this message.Good luck!
