Wire to rope splice
From Practical Sailor -snip---Two of the bookscontaining instructions are: PracticalKnots & Ropework, by Percy W.Blandford (Tab Books, Inc, Blue RidgeSummit, PA 17214),and The DittyBag Book, by Frank Rosenow(SailBooks, 34 Commercial Wharf,Boston, MA 02110).snip---Here's one way to splice, borrowed from the link below. If you can visualize it, it should work.snip---2) WIRE TO ROPE (double braid) SPLICE - Basically, this is splicing the rope core to the wire, then over and beyond that with the rope cover to the wire. You will need a special fid, or marlinspike, to open the wire for tucking the strands, and plastic rigging tape to tape the rope and wire. It would be most helpful if you know how to splice 3-strand rope, since the tucking technique is the same, and practicing on just rope will give you the experience you need to visualize the splice as you go up the wire. Read all instructions through completely before starting to help you visualize each step. When the splice is complete, you will have a spliced length that will have: approximately two (2) feet of double braid line with a tapered wire core inside. Approximately six to eight inches of rope core spliced into the wire, covered by intact rope cover. A final length of wire with the rope cover spliced into it for another six to eight inches up the wire. FIRST: Taper the wire:For one (1) foot, unlay strands exposing the core wire.Alternating strands, CUT: * 1 strand off at one (1) foot * 1 strand off four (4) inches higher * 1 strand off at the next 4” higher * 1 strand off at the next 4” higher until all strands are cut – you will have only the center extending down alone for one (1) foot below rest of wire strands. NOTE: you could make the strand cuts every three (3) inches, but the splice will be a bit tighter and lumpier along this length of tapered wire. Starting two (2) inches up from the last cut wire strand, tape the wire tightly all the way down to the end. This taped, tapered portion of the wire will stay inside the splice like that forever. SECOND: Rope. * Expose the core and cut off approximately eight (8) inches. * Measure another eight (8) inches of core and put a piece of tape around. Unravel the eight (8) inches of exposed core below the tape. Thread the taped, tapered wire into the core. * Count off core strands, divide by three (3), and tape each bundle neatly. SPLICING WITH THE LAY: * Four (4) full tucks. Each bundle under two (2) strands of wire – the same bundle will tuck under the same wire strand up the line. * After four (4) tucks, taper: cut off one strand bundle, tuck up the rest. Cut off next strand bundle, tuck up the rest, until taper done. * When core splice is finished, milk the cover over the core/wire splice. You’ll have approximately eight (8) inch overlap. Tape the cover at the core/wire end, and splice the cover to the wire the same way the core was done (i.e., four (4) full tucks, then taper.) You now have your basic wire to rope splice.snip--Sail On...Terry
