How to add a 90 degree bend to a Whale diverter valve
14
Tayana Tayana 42 Annapolis, MD
Hi, Thanks for all of the help so far! I was planning on using a Whale diverter valve with my sanitation setup. However, I need to put a 90 degree bend from the diverter valve to a thru hull. What's the best way of doing this and making sure no odor penetrates the connections?
Thanks!
Marty
Jun 9, 2008
1,850
- -- -Bayfield
90 degree turns in head hose is not a great idea. Might clog. You want as smooth a run as you can get. That's my 2 cents.
Dec 2, 1997
9,011
- - LIttle Rock
Best way to do it is an inline radius sweep...
That's inserted into the hose, not attached to the valve. SeaLand has 'em...2nd page here:
SeaLand Hoses and Fittings
Although it's always best to avoid 90 degree elbows whenever possible, 90 degree sweeps aren't any more likely to clog than a straight run...and even elbows aren't THAT likely to clog. Far better to use one, than force a hose to bend that much...that invariably results in kinks and/or leaks.
