I was just curious..is there any way to access the top of your mast without unstepping it and bringing it down to you? My mast light is not working and I wanted to check/change the bulb or check the connections. Are there any tricks to get up there.
I've tried those "Sky Hooks" and they don't seem to work too well.I was just curious..is there any way to access the top of your mast without unstepping it and bringing it down to you? My mast light is not working and I wanted to check/change the bulb or check the connections. Are there any tricks to get up there.
Since I've been retired RAD, I try to refrain from doing anything too laborious, and being a "Geezer", I'm lucky if I can still walk let alone climb a pole. I have to admit that buckets were easier to work out of, but I liked climbing when I was able to do it. I did quite a bit of it when I first started, and today I have those "Veryclose" veins in my legs to prove it.Boy Joe as a old lineman you would think being on top of the mast is second nature, I'm an electrician and I don't mind climbing to the top if it needs to get done, last winter while on the hard I borrowed a bucket truck that had a reach taller than mine (60 ft) to go to top of my buddy's Catalina and my Oday and the bucket would not articulate as it ascended upward, by the time I got done horsing around I should have just went up in a bosuns chair
I removed my steaming light along with the feed wire, last spring. It was something that I had added when I replaced my mast back in the 1990s and I'm sorry that I ever had it installed. The wiring for that light never faired well with the internal halyards and for the few times that I ever used that light, it really wasn't worth having. Outside of that, the wire that fed the mast head light was in good condition, but the outlet and plug needed to be replaced. The contacts in the mast head light needed cleaning, and the bulb was still good. I don't think that I've ever had to replace a bulb in either the mast head, bow, or Stern lights that I can remember. The problems are usually a broken wire, or a corroded and bad connection. I'm glad that you found the problem. I've found that the Dremel Tool is still a good investment for cleaning electric contacts as well as a host of other small tasks on boats and at home.I was playing with the two wires on the base of the mast and if I wiggle one of them the steamer light turns on..so I guess its just a loose or frayed connection..so I dont have to change the bulb which is good..thanks for the replies
