how to access the toilet valve at sea
Apr 24, 2013
26
HUNTER 33 NOUMEA
The sea access valve, the one that allows the toilets to be evacuated directly into the sea, is located behind the black water tank. I need to change the pipe that goes from the Y selection valve to the direct sea outlet valve. How should I do this?
Do I need to make a hole in the transom to have easier access?
User of a HUNTER 33 from 2005 and later, have you had this problem and how did you solve it?
Thank you for your answers
Dec 2, 1997
8,940
- - LIttle Rock
It would be best to ADD a hose from the y-valve to a new below-waterline thru-hull instead of re-routing the hose to the black tank...'cuz unless you're in Asia it's unlikely you'll ever be in waters where you'll never need to use the tank.
--Peggie
Aug 18, 2024
25
Sceptre 41 Vancouver
hopefully ALL your below-waterline "sea access" valves are easy to access... to be able to turn off in case of emergency
Apr 24, 2013
26
HUNTER 33 NOUMEA
Il serait préférable d'AJOUTER un tuyau de la vanne en Y à un nouveau passage de coque sous la ligne de flottaison au lieu de réacheminer le tuyau vers le réservoir noir... car à moins que vous ne soyez en Asie, il est peu probable que vous vous trouviez un jour dans des eaux où vous n'aurez jamais besoin d'utiliser le réservoir.
--Peggie
[/CITATION]
Malheureusement, notre bateau est susceptible de naviguer dans les eaux australiennes et néo-zélandaises et nous souhaitons conserver le réservoir d'eaux noires. (Nous habitons en Nouvelle-Calédonie)
May 1, 2011
4,989
Pearson 37 Lusby MD
Unfortunately our boat is likely to operate in Australian and New Zealand waters and we would like to retain the black water tank. (We live in New Caledonia)
