This spring, I discovered that the shaft nut and tighting nut were nearly off and leaking water. I tightened both them down by hand to where the shaft was not leaking water anymore. I still get a small line of water from the shaft under my engine. My Question is "how do you determine how tight they should be?"Thanks John
